[GRASS-user] db.in.ogr and v.db.join
lami at faunalia.it
lami at faunalia.it
Tue Oct 23 08:47:53 EDT 2007
The problem is that the new column is not conncted to a vector, infact:
db.dropcol -f voti_province colum=cat
Forcing ...
WARNING: Deleting <cat> column which may be needed to keep table connected
to a vector map
ERROR: Column <cat> not found in table
I don't know if I do something not correct...
Thanks
leonardo
> On Tue, Oct 23, 2007 at 10:04:12AM +0200, lami at faunalia.it wrote:
>> Hi all,
>> I'm testing the new databse commands on GRASS 6.3 cvs and I find a
>> problem
>> in db.in.ogr.
>> I'm using SQLite database, when I use db.in.ogr with a cvs or dbf table
>> Grass create the new table on .db SQLite file but it adds a first column
>> called "cat" that are not present in the original table.
> This is strange since the script contains
> # get rid of superfluous auto-added cat column
> db.dropcol --q -f $GIS_OPT_OUTPUT colum=cat >/dev/null 2>/dev/null
> (the cat column is added in the first place since v.in.ogr is
> used, then db.dropcol is called).
> It appears that db.dropcol fails.
> Try to run
> db.dropcol -f yourtable colum=cat
> This will show the error.
> Markus
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
