[GRASS-user] db.in.ogr and v.db.join
Markus Neteler neteler at fbk.eu
Tue Oct 23 15:57:11 EDT 2007
Leo,
congrats - you found a bug in db.dropcol :-) Fixed in CVS.
While doing that, I have also fixed the case that a "cat" column
is already present in the original table (DBF file from a GRASS exported
SHAPE file). Also in CVS (db.in.ogr).
thanks,
Markus
Leonardo Lami wrote:
> The problem is that the new column is not conncted to a vector, infact:
>  db.dropcol -f voti_province colum=cat
> Forcing ...
> WARNING: Deleting <cat> column which may be needed to keep table connected
>          to a vector map
> ERROR: Column <cat> not found in table
> I don't know if I do something not correct...
> Thanks
> leonardo
>> On Tue, Oct 23, 2007 at 10:04:12AM +0200, lami at faunalia.it wrote:
>>> Hi all,
>>> I'm testing the new databse commands on GRASS 6.3 cvs and I find a
>>> problem
>>> in db.in.ogr.
>>> I'm using SQLite database, when I use db.in.ogr with a cvs or dbf table
>>> Grass create the new table on .db SQLite file but it adds a first column
>>> called "cat" that are not present in the original table.
>> This is strange since the script contains
>> # get rid of superfluous auto-added cat column
>> db.dropcol --q -f $GIS_OPT_OUTPUT colum=cat >/dev/null 2>/dev/null
>> (the cat column is added in the first place since v.in.ogr is
>> used, then db.dropcol is called).
>> It appears that db.dropcol fails.
>> Try to run
>> db.dropcol -f yourtable colum=cat
>> This will show the error.
>> Markus
View this message in context: http://www.nabble.com/db.in.ogr-and-v.db.join-tf4675839.html#a13372418
Sent from the Grass - Users mailing list archive at Nabble.com.
