[GRASS-user] 6.3 cvs in gutsy
Tomas Lanczos
lanczos at t-zones.sk
Mon Oct 29 13:55:59 EDT 2007
Hi Maris,
the hangup occurs when I select the mapset from the list, only the
Outputs window is opened and then it's hanging. I tried also older cvs
packages, it's the same.
I don't know whether is it a clue, but during the Ubuntu upgrade I lost
somwhere the gdal-config file, so I recompiled the GDAL (version 1.4.0).
After that I compiled the GRASS 6.3 CVS, using this script for the
configure:
./configure --with-tcltk-includes=/usr/include/tcl8.4 \
--with-odbc \
--with-freetype --with-freetype-includes=/usr/include/freetype2 \
--with-readline --with-cxx --enable-largefile \
--with-postgres-includes=/usr/include/postgresql \
--with-postgres-libs=/usr/lib/postgresql/8.2/lib \
--with-python \
--with-proj-share=/usr/local/share/proj
regards and thanks for the help
Tomas
Maris Nartiss wrote:
> Hi Tomas,
> how You started GRASS? Does it hanged on startup or when gis.m was
> launched from terminal?
> Could this be the source of Your problem?
> http://wald.intevation.org/tracker/index.php?func=detail&aid=521&group_id=21&atid=205
> Maris.
> 2007/10/28, Tomas Lanczos <lanczos at t-zones.sk>:
>> Yesteday I upgraded my Ubuntu Feisty to the Gutsy Gibbon. When I
>> compiled the last cvs, I could not start the GIS manageger, opened the
>> Outputs windows and stayed hanging. Did somebody else recognize this
>> behavior and/or solved the problem?
>> Thanks and regards
>> Tomas
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
