[*** SPAM ***] Re: [GRASS-user] 6.3 cvs in gutsy
Malte Halbey-Martin
malte at perlomat.de
Mon Oct 29 15:28:25 EDT 2007
Hi Tomas,
Here are some of my problems with gdal-issues compiling GRASS 6.3 from cvs:
I ran into problems after I compiled 6.3. I couldn't start GRASS, it
always crashed of missing libgdal.XXX.so1 (in that manner you described)
After creating symlink to the existing libgdal.1.3.2.so.1, it all whent
fine.
Did the problem occur, when you use the --with-gdal option when you run
./configure
--with-gdal=/usr/bin/gdal-config
Maybe you have to add the libs to your /etc/ld.so.conf. Is there an
entry like /usr/lib?
If not, add it and run sudo ld.config.
As I said, these are the traps where I've been caught by compiling GRASS
from source. Hope one of these helps ;-)
Malte
Tomas Lanczos schrieb:
> Hi Maris,
> the hangup occurs when I select the mapset from the list, only the
> Outputs window is opened and then it's hanging. I tried also older cvs
> packages, it's the same.
> I don't know whether is it a clue, but during the Ubuntu upgrade I lost
> somwhere the gdal-config file, so I recompiled the GDAL (version 1.4.0).
> After that I compiled the GRASS 6.3 CVS, using this script for the
> configure:
> ./configure --with-tcltk-includes=/usr/include/tcl8.4 \
> --with-odbc \
> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
> --with-readline --with-cxx --enable-largefile \
> --with-postgres-includes=/usr/include/postgresql \
> --with-postgres-libs=/usr/lib/postgresql/8.2/lib \
> --with-python \
> --with-proj-share=/usr/local/share/proj
> regards and thanks for the help
> Tomas
> Maris Nartiss wrote:
>> Hi Tomas,
>> how You started GRASS? Does it hanged on startup or when gis.m was
>> launched from terminal?
>> Could this be the source of Your problem?
>> http://wald.intevation.org/tracker/index.php?func=detail&aid=521&group_id=21&atid=205
>> Maris.
>> 2007/10/28, Tomas Lanczos <lanczos at t-zones.sk>:
>>> Yesteday I upgraded my Ubuntu Feisty to the Gutsy Gibbon. When I
>>> compiled the last cvs, I could not start the GIS manageger, opened the
>>> Outputs windows and stayed hanging. Did somebody else recognize this
>>> behavior and/or solved the problem?
>>> Thanks and regards
>>> Tomas
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
