[*** SPAM ***] Re: [GRASS-user] 6.3 cvs in gutsy
Tomas Lanczos lanczos at t-zones.sk
Mon Oct 29 18:53:07 EDT 2007
Hi Malte,
yesss that was it, works now! I had a feeling that I missed something
after the Ubuntu upgrade ... thanks for the recall, I appreciate it,
very much :-).
Many thanks for everybody who gave advices, grass is a great thing, as
well as the whole community around it :-D.
regards
Tomas
Malte Halbey-Martin wrote:
> Hi Tomas,
> Here are some of my problems with gdal-issues compiling GRASS 6.3 from cvs:
> I ran into problems after I compiled 6.3. I couldn't start GRASS, it
> always crashed of missing libgdal.XXX.so1 (in that manner you described)
> After creating symlink to the existing libgdal.1.3.2.so.1, it all whent
> fine.
> Did the problem occur, when you use the --with-gdal option when you run
> ./configure
> --with-gdal=/usr/bin/gdal-config
> Maybe you have to add the libs to your /etc/ld.so.conf. Is there an
> entry like /usr/lib?
> If not, add it and run sudo ld.config.
> As I said, these are the traps where I've been caught by compiling GRASS
> from source. Hope one of these helps ;-)
> Malte
> Tomas Lanczos schrieb:
>> Hi Maris,
>> the hangup occurs when I select the mapset from the list, only the
>> Outputs window is opened and then it's hanging. I tried also older cvs
>> packages, it's the same.
>> I don't know whether is it a clue, but during the Ubuntu upgrade I lost
>> somwhere the gdal-config file, so I recompiled the GDAL (version 1.4.0).
>> After that I compiled the GRASS 6.3 CVS, using this script for the
>> configure:
>> ./configure --with-tcltk-includes=/usr/include/tcl8.4 \
>> --with-odbc \
>> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>> --with-readline --with-cxx --enable-largefile \
>> --with-postgres-includes=/usr/include/postgresql \
>> --with-postgres-libs=/usr/lib/postgresql/8.2/lib \
>> --with-python \
>> --with-proj-share=/usr/local/share/proj
>> regards and thanks for the help
>> Tomas
>> Maris Nartiss wrote:
>>> Hi Tomas,
>>> how You started GRASS? Does it hanged on startup or when gis.m was
>>> launched from terminal?
>>> Could this be the source of Your problem?
>>> http://wald.intevation.org/tracker/index.php?func=detail&aid=521&group_id=21&atid=205
>>> Maris.
>>> 2007/10/28, Tomas Lanczos <lanczos at t-zones.sk>:
>>>> Yesteday I upgraded my Ubuntu Feisty to the Gutsy Gibbon. When I
>>>> compiled the last cvs, I could not start the GIS manageger, opened the
>>>> Outputs windows and stayed hanging. Did somebody else recognize this
>>>> behavior and/or solved the problem?
>>>> Thanks and regards
>>>> Tomas
>>>> _______________________________________________
>>>> grassuser mailing list
>>>> grassuser at grass.itc.it
>>>> http://grass.itc.it/mailman/listinfo/grassuser
