[GRASS-user] Georeferencing DXF files.
Markus Neteler
neteler at itc.it
Thu Sep 6 00:50:16 EDT 2007
Hi Antonio,
after import with v.in.dxf, use v.transform to do the georeferencing.
Then export as shapefile (I understand that you want it as SHAPE file
in the end?).
Markus
Antonio Gennarini-3 wrote:
> Hi all.
> I finally managed to import dxf files in GRASS 6.2 and subsequently
> export the vector data as a shapefile. However, the shapefiles are not
> georeferenced.
> Now, I'm wondering if I can georeference the shapefile or do I need to
> make sure that the dxf is georeferenced prior to importing it in GRASS.
> THe reason why I ask is that to georeference a huge 50MB dxf file, I
> need the help of autocad but I would like to avoid using this
> proprietary software .... Anybody aware of how to georeference vector
> data? Maybe within GRASS (so after importing the dxf but before
> exporting the shapefile)?
> Many thanks
> Antonio Gennarini
> (Environmental Consultant)
> ESI Ltd
> Soil and Groundwater Specialists
> New Zealand House
> 160, Abbey Foregate
> Shrewsbury SY2 6FD
> United Kingdom
> Telephone: +44 (0)1743 276100 Direct Dial: +44 (0)1743 276145
> Fax: +44 (0)1743 248600
> Email antoniogennarini at esinternational.com
> <http://www.esinternational.com>
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
View this message in context: http://www.nabble.com/Georeferencing-DXF-files.-tf4388281.html#a12515579
Sent from the Grass - Users mailing list archive at Nabble.com.
