[GRASS-user] edit category information?
Glynn Clements
glynn at gclements.plus.com
Fri Sep 7 16:15:18 EDT 2007
Hamish wrote:
> Seems messy- Probably better to have a new r.support.cats module to take
> care of that? Writing the cats file is so simple I don't know if it
> really needs its own C module, or if you can just write out the file
> directly from the GUI.
Regardless of how simple the format is, there should be a C module to
do this. If the format were ever changed, the only code which should
need to be changed is lib/gis/cats.c.
