[GRASS-user] trying to get unprojected raster data into a
projected location
Maciej Sieczka
tutey at o2.pl
Fri Sep 21 03:54:10 EDT 2007
Pietro Calogero wrote:
> I received a set of data that was developed in ArgGIS, including
> shapefiles and a .sid raster file. The shapefiles came with
> projection information, but the .sid file did not (and it extends
> out further than the vector info on the edges)
This shouldn't be a big problem. If you are sure your SID raster is in
the same projection that your shapefiles just use flag -o in r.in.gdal
which will override the projection check.
Let me know if that helps.
Maciek
