[GRASS-user] r.out.gdal bug? problems with createopt
    Martin Landa
    landa.martin at gmail.com
    Mon Sep 24 05:17:28 EDT 2007
preparing the patch, I realized there is something strange, createopt
works only using MEM driver...
GDALCreateCopy, works:
  /* Finaly create user required raster format from memory raster if
in-memory driver was used */
    if (hMEMDS) {
	hDstDS =
	    GDALCreateCopy(hDriver, output->answer, hMEMDS, FALSE, papszOptions,
			   NULL, NULL);
	if (hDstDS == NULL)
	    G_fatal_error(_("Unable create raster map <%s> using driver <%s>"),
			  output->answer, format->answer);
GDALCreate(), createopt seems to be ignored(?)
	hDstDS =
	    GDALCreate(hDriver, output->answer, cellhead.cols, cellhead.rows,
		       ref.nfiles, datatype, papszOptions);
Martin
2007/9/24, Markus Neteler <neteler at itc.it>:
> Markus Neteler wrote:
> > Hi Robert,
> > it seems to be the same bug as it was found and fixed in v.out.ogr
> > some days ago by Martin.
> > I debugged a bit and found that the second part
> > "PROFILE=BASELINE" isn't passed. It gets lost in
> > main.c, line 554.
> > v.out.ogr's main.c (line 249 etc) has a working solution
> > but my try to port it to r.out.gdal failed (no idea why, should be
> > rather easy - but it segfaults for me).
> What about moving this multi-option code to
> G_store_multi() or something like this?
> Modules with multi-option parameters are
> - r.out.ogr
> - v.out.ogr
> - v.transform (new column parameter)
> - maybe others
> Markus
> View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a12855513
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
