[GRASS-user] finding bounding box of
polygons
Gerald Nelson
gnelson at uiuc.edu
Sun Sep 30 21:33:05 EDT 2007
The following command
ogrinfo -al -where 'CNTRY_NAME=GERMANY' SubNationalboundaries.shp
gets me all the attributes for Germany in the shapefile. This includes a POLYGON attribute for each subnational unit with a bunch of lat-long values, but does not, as far as I can tell, get me a bounding box.
Any other suggestions appreciated.
Jerry
---- Original message ----
>Date: Sun, 30 Sep 2007 16:56:25 -0700
>From: "John C. Tull" <john.tull at wildnevada.org>
>Subject: Re: [GRASS-user] finding bounding box of polygons
>To: Jerry Nelson <gnelson at uiuc.edu>
>You can run a query on ogrinfo with -where, but I am not certain if
>the bounds will reflect the query. I would suspect as much.
>http://www.gdal.org/ogr/ogrinfo.html
>Cheers,
>John
>On Sep 30, 2007, at 3:19 PM, Jerry Nelson wrote:
>> What I'm trying to do is get the bounding boxes around each country
>> in the
>> world, so I can create a region file for each. This would make doing
>> graphics by country much easier. For example, we have constructed a
>> raster
>> at 1 km resolution of the number of amphibian species ranges at each
>> location for the whole world. There are times when I just want, say
>> the
>> counts in India. We have a nice little script that generates a png
>> automatically based on a region file. It would be nice to have such
>> a file
>> for each country in the world.
>> If I read your example correctly, ogrinfo gives me the box around
>> the entire
>> shapefile, not individual polygons. I suppose an alternative would
>> be to
>> somehow export each country polygon as a separate shapefile and get
>> the
>> region of that.
>> Any tips appreciated.
>> Thanks, Jerry
>> -----Original Message-----
>> From: Jose Gomez-Dans [mailto:jgomezdans at gmail.com]
>> Sent: Thursday, September 27, 2007 4:59 PM
>> To: Jerry Nelson
>> Cc: grassuser at grass.itc.it
>> Hi,
>> On 9/27/07, Jerry Nelson <gnelson at uiuc.edu> wrote:
>>> I'd like to construct a list of the bounding box coordinates for
>>> all the
>>> polygons in a vector file. I could find nothing in the manual that
>>> seemed
>> to
>>> do that. Any tips appreciated.
>> Not a GRASS-centric response :), but if it is just a box you're after,
>> you can probably use ogrinfo for this, as it gives you the Extent of
>> your file. As an example, using it with the world.shp Shapefile
>> results in:
>> $ ogrinfo -so python/world.shp world
>> INFO: Open of `python/world.shp'
>> using driver `ESRI Shapefile' successful.
>> Layer name: world
>> Geometry: Polygon
>> Feature Count: 244
>> Extent: (-180.000000, -89.900000) - (180.000000, 83.674733)
>> Layer SRS WKT:
>> (unknown)
>> CAPITAL: String (64.0)
>> APPROX: Real (15.0)
>> AREA: Real (20.15)
>> SOURCETHM: String (16.0)
>> Hope that helps
>> grassuser mailing list
>> http://grass.itc.it/mailman/listinfo/grassuser
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
