[GRASS-user] Fixing Collared DRGs
Tom Russo
russo at bogodyn.org
Wed Apr 2 16:16:16 EDT 2008
On Wed, Apr 02, 2008 at 12:51:35PM -0700, we recorded a bogon-computron collision of the <Craig at pid.co.za> flavor, containing:
> Tom Russo wrote:
> > v.to.rast input=o48112d2_bounds output=o48112d2_bounds use=val value=1
> > (this one generates a raster that's 1 inside the neatline, null
> > outside)
> > echo
> > "o48112d2_withoutcollar=if(!isnull(o48112d2_bounds),o48112d2_withcollar,null())"
> > | r.mapcalc
> > (this populates the _withoutcollar map only where the mask is
> > non-null)
> > (you could also do it with
> > r.mask input=o48112d2_bounds
> > echo "o48112d2_withoutcollar=o48112d2_withcollar"| r.mapcalc
> > r.mask -r
> Hi
> Another way is to use gdal_rasterize. See point e) under the Mosaicing
> section of this tutorial by Frank Warmerdam:
> http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
Neat. The same 24kgrid shapefile could be the source of the vector clipping
region for that technique, too. Thanks for pointing that out, I hardly
ever use gdal_rasterize and didn't know it could do that.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
