[GRASS-user] Vector not displaying labels from Layer 2
Richard Chirgwin rchirgwin at ozemail.com.au
Mon Apr 7 01:41:13 EDT 2008
Jachym, many thanks. I didn't realise that in this version (6.2) I have
to have labelling on Layer 1 - I wish you well with the Debian patch
system.b The output I copied below was from the GIS.m output - not the
command line.
(For other Freespire users, the Ubuntu build is the only one I could get
to work - I'm only a Linux newbie and wasn't brave enough to try
building from source!)
Another (really stupid) question. I want to run r.los, but it needs an
eastings-northings location. I can't, however, see how to get the right
extents for creating location. I'm happy to move the relevant raster
into a new location, but how do I create a target location with the
correct eastings/northings values?
Richard
Jachym Cepicky wrote:
> hi,
> Richard Chirgwin pís(e v Ne 06. 04. 2008 v 16:53 +1000:
>> d.vect map=Australia color=0:0:0 lcolor=0:0:0 fcolor=170:170:170
>> display=shape type=point,line,boundary,centroid,area icon=basic/circle
>> size=5 layer=1 lsize=8 xref=left yref=center llayer=2
> you did not say, you want to see any labels. display=shape,attr
> attrcol=label_column_name should do the job
> martin already told you, that you need layer 1 in grass 6.2
> I would like to prepare grass63 packages, however, I'm fighting with the
> debian dpatch system currently (frankie, any howto?)
> jachym
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080407/fc91573e/attachment.html
