[GRASS-user] v.in.ascii - put1 of 4 columns to 3D point file attribute
M S mseibel at gmail.com
Wed Apr 9 08:55:51 EDT 2008
Greetings GRASSers:
First I'd like to say what a great book the Open Source GIS: A GRASS GIS
Approach (3rd edition) is.  It is full of great practical and conceptual
examples.  Well worth the money to anyone who has not purchased it yet!
Also a big thanks to the developers and users of GRASS who make it a
powerful and amazing GIS.
I have an ascii table of lidar data.  The columns are x,y,z, and a fourth
column containing an integer code of some sort.  I have looked at the
example in the man page about how to select columns for importing via some
shell manipulation of the input ascii file, but I do not think it is
applicable to what I'm doing (or perhaps the caffeine boost is not in effect
yet).  I have also tried various combinations of parameters in v.in.ascii.
I would like to import the XYZ to build the geometry for 3D points, and have
only "Cat" and "Code" in the attribute table.  ("Code" being a column name
for the 4th column in the input ASCII).  I cant seem to find the combination
of column definitions and other parameters to achieve this.  One option
seems to import them all as "x double, y double, z double, code int", and
then after the import, drop the x,y,z columns.  Is it possible to put the
first 3 ASCII column values to the geometry, and use only the last column as
an attribute?
I'm using GRASS 6.2.3 and sqlite database.
Thanks out to anyone with some feedback.
Mark
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080409/a0cad700/attachment.html
