[GRASS-user] Question about MODIS band 5 destriping?
Glynn Clements
glynn at gclements.plus.com
Wed Apr 9 23:09:50 EDT 2008
Markus Neteler wrote:
> > > I think that the strange i.fft file format is an obstacle here. AFAIK it
> > > is not saved as "normal" raster file which limits the possibilities to
> > > elaborate. Maybe I am wrong, don't quite remember well..
> > No, you're quite correct.
> > i.ifft ignores the actual input map, reading the data from the fftreal
> > and fftimag files created by i.ifft. So you can't modify the i.fft
> > output with e.g. r.mapcalc than use i.ifft on the result. The only
> > modification which can be performed on the FFT data is masking; i.ifft
> > reads the mask separately and applies it to the data.
> Could we change this for GRASS 7? Possibly there was a reason
> to implement it as private solution but hopefullyx we can work around
> that.
The main issue is that you can't store both the real and imaginary
components (or, alternatively, magnitude and phase) in a single map.
The other issues (e.g. the fact that an array of FFT coefficients
isn't actually geodata) can probably be fudged around.
