[GRASS-user] Question about MODIS band 5 destriping?
Markus Neteler
neteler at osgeo.org
Wed Apr 9 15:37:57 EDT 2008
On Wed, Apr 9, 2008 at 6:11 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
> > I think that the strange i.fft file format is an obstacle here. AFAIK it
> > is not saved as "normal" raster file which limits the possibilities to
> > elaborate. Maybe I am wrong, don't quite remember well..
> No, you're quite correct.
> i.ifft ignores the actual input map, reading the data from the fftreal
> and fftimag files created by i.ifft. So you can't modify the i.fft
> output with e.g. r.mapcalc than use i.ifft on the result. The only
> modification which can be performed on the FFT data is masking; i.ifft
> reads the mask separately and applies it to the data.
Could we change this for GRASS 7? Possibly there was a reason
to implement it as private solution but hopefullyx we can work around
that.
Markus
