[GRASS-user] areas
Moritz Lennert
mlennert at club.worldonline.be
Fri Apr 11 08:53:08 EDT 2008
On 11/04/08 14:42, Isabel Alfaro Cardozo wrote:
> hi, I was wondering if it is posible to measure areas and distances
> inside GRASS, and save the values in a table.
> wich commands do I have to use?
This depends whether you work in raster or vector, but in vector look at
the following:
v.to.db
v.distance
For raster maps you should check out
r.distance
r.stats (possible with r.clump)
Moritz
> thank you
> Isabel
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
