[GRASS-user] Another error with wxpython GUI in RC6
Martin Landa
landa.martin at gmail.com
Sat Apr 12 08:39:09 EDT 2008
> 1/ I tried compiling using --with-python=no --with-wxwidgets
> But with svn revision 30941 I get:
> Errors in:
> /home/dad/grass63_release_build/grass63_release/gui/wxpython/vdigit
> In case of errors please change into the directory with error and run
> 'make'.
now should be fixed in trunk and releasebranch_63, see
http://trac.osgeo.org/grass/changeset/30951
when you run
svn up
./configure ... --with-python=no ...
vdigit will be not compiled, i.e. it requires both --with-python and
--with-wxwidgets.
> So it seems that to have the wxPython gui I need to have swig installed.
No, swig is need only for compilation of vector digitizer, wxGUI
(without digitizer) is installed regardless of any configuration
switch.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
