[GRASS-user] Another error with wxpython GUI in RC6
geep999
geep999 at yahoo.co.uk
Sat Apr 12 11:14:57 EDT 2008
Hi Martin, Glynn & everybody,
Problem solved (accidentally!) - not totally sure how.
And found a new (to me!) dependency - NumPy.
1/ When I started "grass63 -wxpython" the first few times I was in my home
directory.
When I got the nasty error messages initially reported I did not have any
GIS Data.
Later I copied a GIS Data Directory from another PC into $HOME/MountDoom
Then:
cd $HOME/MountDoom
grass63 -wxpython (whilst in $HOME/MountDoom)
No more nasty error messages, instead I got this:
dad at VMSLACK12_1_RC1:~/MountDoom$ grass63 -wxpython
Cleaning up temporary files.....
Starting GRASS ...
GRASS GUI should be wxpython
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 6.3.0svn (2008)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.3.0svn (MountDoom):~/MountDoom > profile.py:
This module requires the NumPy module,
which could not be imported. It probably is not installed
(it's not part of the standard Python distribution). See the
Numeric Python site (http://numpy.scipy.org) for information on
downloading source or binaries.
2/ So, I installed this new dependency ;) NumPy.
Lo and behold, without so much as a ./configure or make, I find that
grass63 -wxconfig is running with a shiny new interface.
3/ It seems that launching from within $HOME/MountDoom was somehow the trick
that got me started,
and stopped the nasty error messages.
I note that -wxpython and -tcltk show different Project Locations
when launched from my $HOME directory.
-tcltk lists all directories in $HOME in the Project Location box
-wxpython only lists directory MountDoom in the Project Location box
Cheers,
Peter
Martin Landa-2 wrote:
> Hi,
>> 1/ I tried compiling using --with-python=no --with-wxwidgets
>> But with svn revision 30941 I get:
>> Errors in:
>> /home/dad/grass63_release_build/grass63_release/gui/wxpython/vdigit
>> In case of errors please change into the directory with error and run
>> 'make'.
> now should be fixed in trunk and releasebranch_63, see
> http://trac.osgeo.org/grass/changeset/30951
> when you run
> svn up
> ./configure ... --with-python=no ...
> vdigit will be not compiled, i.e. it requires both --with-python and
> --with-wxwidgets.
>> So it seems that to have the wxPython gui I need to have swig installed.
> No, swig is need only for compilation of vector digitizer, wxGUI
> (without digitizer) is installed regardless of any configuration
> switch.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Another-error-with-wxpython-GUI-in-RC6-tp16627913p16650263.html
Sent from the Grass - Users mailing list archive at Nabble.com.
