[SOLVED] Re: [GRASS-user] Error when defining projection from a
georeferenced file, help needed.
Andrew Parker
andrew at source3.com
Mon Apr 28 09:02:30 EDT 2008
That worked. I used:
#export GRASS_TERMINAL=xterm
Thank you very very much everyone.
FYI: I upgraded to Ubuntu 8.04 (Hardy) and using Grass 6.2.2 from the
repositories. I have not yet installed Grass 6.3
Andrew Parker
Source3 Computing LLC
www.source3.com
505-350-5535
On Mon, 2008-04-28 at 13:23 +0100, Glynn Clements wrote:
> Andrew Parker wrote:
> > Just tried exporting the terminal xterm (GRASS_TERMINAL=xterm). Same
> > error.
> FWIW, the variable which determines which terminal emulator to use is
> named GRASS_XTERM, not GRASS_TERMINAL.
