Andrew Parker wrote: > Just tried exporting the terminal xterm (GRASS_TERMINAL=xterm). Same > error. FWIW, the variable which determines which terminal emulator to use is named GRASS_XTERM, not GRASS_TERMINAL. -- Glynn Clements <glynn at gclements.plus.com>
