[GRASS-user] Error when defining projection from a georeferenced file, help needed.
Andrew Parker andrew at source3.com
Sun Apr 27 09:06:11 EDT 2008
Thanks Markus and Hamish.
Hamish: that's not fair!  Is searched the mailing list for the error
before posting but didn't get any results.
I also considered installing 6.3 from source.  Decided to post first.  I
will upgrade to Ubuntu Hardy and try GRASS from the repo to see if it
works (out of curiosity) then report back.  Then I will install 6.3 from
source.
I tried the *.shp file before posting.  Same error.
Just tried exporting the terminal xterm (GRASS_TERMINAL=xterm).  Same
error.
Well, time to backup and install Hardy.
Thanks for the help.
Andrew Parker
On Sun, 2008-04-27 at 10:43 +0200, Markus Neteler wrote:
> On Sun, Apr 27, 2008 at 3:20 AM, Hamish <hamish_b at yahoo.com> wrote:
> >  > After starting a new project using the "start new location with a
> >  > georeferenced file" option, I get an error when I click "Define
> >  > Location". I am using the North Carolina sample data and using the
> >  > gdc.prj for the georeferenced file.
> Indeed, I also get that error.
> >  Maybe it works, I'm not sure - it might just concentrate on the layer
> >  name not the extension - but I thought it wanted the .shp file for that,
> >  not the .prj file that comes with it? (from within GRASS,  you can feed
> >  it that definition with 'g.proj wkt=gdc.prj')
> There is a .shp file too, please use that file.
> @developers: I think that we need a test in the location definition part of
> the code if the user provided a .prj file or something else to make use
> of the right g.proj parameters.
> It is function proc epsgOpt::runproj in lib/init/epsg_option.tcl
> >  > The error is as follows:
> >  > /usr/bin/x-terminal-emulator: to set an icon, please use -name
> >  > <profile>
> >  > and set a profile icon
> This is an Ubuntu bug. In GRASS 6.3 this part was modified to
> also work with Ubuntu. Please consider to update (hopefully
> an Ubuntu package comes out soon).
> Good luck with your project
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
