[GRASS-user] execute commands automatically after start of grass
Rainer M Krug r.m.krug at gmail.com
Fri Aug 1 08:38:03 EDT 2008
On Fri, Aug 1, 2008 at 2:35 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Why not put a test inside .grass.bashrc to check if you are in the
> mapset you want R to run?
> Something like:
> <pseudo-code here - can't remember bash sintax>
> if [ $MAPSET = __your_targuet__ ]; do
>   r &
>  emacs &
> fi
Good idea - I think I will go that way.
Rainer
> Cheers
> Daniel
> On Fri, Aug 1, 2008 at 6:23 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> On Fri, Aug 1, 2008 at 11:16 AM, Jachym Cepicky
>> <jachym.cepicky at gmail.com> wrote:
>>> hi,
>>> you can adjust anything in .grass.bashrc file
>>> e.g.
>>> #!/bin/sh
>>> export GRASS_ADDON_PATH=$HOME/usr/grass/
>>> export GRASS_PAGER=/bin/more
>> Thanks - that looks exactly what I am looking for.
>> But is there a way of specifying a certain .grass.bashrc which should be used?
>> The reasoning is that for certain projects I need R and emacs and
>> would like to start them automatically, for others not. Obviously, I
>> could use a startup script which renames the apropriate file to
>> .grass.bashrc, but it would be cleaner to be able to specify it when
>> starting grass.
>>> jachym
>>> [1] http://grass.osgeo.org/grass64/manuals/html64_user/variables.html
>>> 2008/8/1 Rainer M Krug <r.m.krug at gmail.com>:
>>>> Hi
>>>> I am using grass in combination with R, wherefore I have to start R
>>>> (or emacs) after starting grass.
>>>> Is there any way, to make this automatic, i.e., can I specify a script
>>>> which is executed inside grass after it is started?
>>>> In addition, I only would like that to happen when I start grass in a
>>>> certain mapset and not in other mapsets.
>>>> Thanks
>>>> Rainer
>>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>>> Biology, UCT), Dipl. Phys. (Germany)
>>>> Plant Conservation Unit
>>>> Department of Botany
>>>> University of Cape Town
>>>> Rondebosch 7701
>>>> South Africa
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky gmail com
>>> URL: http://les-ejk.cz
>>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>> Centre of Excellence for Invasion Biology
>> Faculty of Science
>> Natural Sciences Building
>> Private Bag X1
>> University of Stellenbosch
>> Matieland 7602
>> South Africa
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
