[GRASS-user] Workflow of a classification project with orthophotos
G. Allegri giohappy at gmail.com
Fri Aug 1 09:29:40 EDT 2008
A collegue sent me this ticks to run OSSIM on Ubuntu 7.10:
http://trac.osgeo.org/ossim/wiki/Ubuntu-7.10Build
after every make make install, give a "ldconfig" and start another
shell to continue the compilation.
in /etc/ld.so.conf.d/
I've exported the following libs :
/usr/lib
/usr/local/lib
/home/sasha/GIS/ossim/ossim/lib
within a file "ossim.conf"
Yet I've never found the time to try it...
Giovanni
2008/8/1 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> On Fri, 2008-08-01 at 12:01 +0200, Maciej Sieczka wrote:
>> Nikos Alexandris pisze:
>> > how do Open Source Professionals image normalisation for aerial
>> > photos... let's say 300 photos? I cannot imagine that people sit-down
>> > and extract psuedoinvariant targets for 300 photos (except they are
>> > payed a lot for that).
>> Nikos,
>> Have you looked at OSSIM? Not that I'm sure it provides the tool, but
>> seems likely.
> Thanks for the suggestion Maciej.
> OSSIM sounds very promising (from what I've read so far). Till today I
> never managed to get OSSIM running under Ubuntu. I've seen it only under
> some win-boxes and partially running under wine. But it's probably an
> adventure to compile it properly.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
