[GRASS-user] Compiling addons from svn repository
gianluca massei
g_massa at libero.it
Mon Aug 4 10:37:31 EDT 2008
I've clean up a little bit r.roughset and I've write some explanation
note. In the next weeks I'll improve documentation (and the English !)
Thanks
Gianluca
Moritz Lennert ha scritto:
> On 04/08/08 14:52, gianluca massei wrote:
>> Thanks Moritz , great tip!
>> I'm working in a module that implemented ELECTRE algorithm.
>> I've just finisced a module named /r.roughset/ for knowledg discovery
>> with rough set based on rough set library. You can download the
>> source code from grass wiki
>> (http://grass.osgeo.org/wiki/GRASS_AddOns#r.roughset) and I'm happy
>> if sameone caould try it and report me tips or bugs.
> It would be easier to test if the module description was a bit more
> elaborate. You should add a description.html with at least a 'Notes'
> section to explain the module and its parameters.
> [BTW, you might want to clean up the source tar ball a bit and delete
> the temporary files it includes, i.e. r.roughset.tmp.html and the ~
> files.]
> Moritz
> Database dei virus interno non c aggiornato.
> Controllato da AVG - http://www.avg.com Versione: 8.0.138 / Database
> dei virus: 270.5.10/1584 - Data di rilascio: 31/07/2008 12.00
