[GRASS-user] Multiple errors after lengthy absence from Grass 7
Martin Landa landa.martin at gmail.com
Wed Aug 6 15:42:01 EDT 2008
> After a fresh make distclean, and a lengthy svn update, Grass 7 fails to start up and exits with an error "ERROR: Incompatible library version for module".
> Checking the error.log, I see the following:
> GRASS GIS compilation log
> Started compilation: Wed Aug  6 16:09:24 ADT 2008
> Errors in:
> /usr/local/grass_trunk/display/d.colors
> /usr/local/grass_trunk/general/g.setproj
see
http://trac.osgeo.org/grass/changeset/32551
grass7 started...
Switch to develbrach_6 if you expect something stable...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
