[GRASS-user] exporting raster map to another projection
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Aug 7 05:35:33 EDT 2008
On Thu, 2008-08-07 at 00:29 -0300, Milton Cezar Ribeiro wrote:
> Dear all,
> I have a a mapset on Lambert Azimuthal Equal Area projection,
> and I would like to export my raster maps to another projection
> (Lat/Long - WSG84 datum). I need to export my maps to
> ASC format. Need I to reproject my maps first or can I
> change the projection during the export?
> By the way, I am running native wingrass 6.3.0 under windows/XP.
> Cheers
> miltinho astronauta
> brazil
> | Type of Map: raster Number of Categories: 65535
> | Data Type: CELL
> | Rows: 11882
> | Columns: 9341
> | Total Cells: 110989762
> | Projection: Lambert Azimuthal Equal Area
> | N: 6443500 S: -5438500 Res: 1000
> | E: 4985500 W: -4355500 Res: 1000
> | Range of data: min = 0 max = 65535
> | Data Description:
> | generated by r.in.bin
Hi!
-Using exclusively GRASS modules I think you must (1) reproject in
another location (with r.proj) and (2) export (with r.out.*). Pay
attention to the current region settings (check/set extent and
resolution with g.region).
-Using gdal utilities you might be able to reproject and export in one
step [1]
Kind regards, Nikos
[1]
http://gfoss.blogspot.com/2008/06/gdal-raster-data-tips-and-tricks.html
