[GRASS-user] Multiple errors after lengthy absence from Grass 7
Patton, Eric epatton at nrcan.gc.ca
Thu Aug 7 09:04:11 EDT 2008
>As Martin says, GRASS 7 development has now started. The first phase
>of development is to eliminate deprecated functionality. This will
>break stuff. Eventually we should get around to replacing most of the
>stuff which breaks with more usable alternatives. In the meantime, use
>6.4 if you just want a working version.
Great, thanks for the update. I'll stick to using 6.4.
~ Eric.
