[GRASS-user] vector layer labelling doesn't work....
G. Allegri giohappy at gmail.com
Fri Aug 8 10:45:16 EDT 2008
Thanks Moritz, sorry for the stupid question...staying all the day in
front of the screen I coudn't see I was missing centroids :-)
2008/8/8 Moritz Lennert <mlennert at club.worldonline.be>:
> On 08/08/08 11:06, G. Allegri wrote:
>> Hi all,
>> it's the first time I try to use labelling on a polygonal vector layer
>> in grass 6.4.svn, and I can't make it work.
>> d.vect map=sst_sardegna at CRA-TASK2 -c color=0:0:0 lcolor=0:0:0
>> fcolor=170:170:170 display=shape,attr type=point,line,boundary,area
>> icon=basic/circle size=5 layer=1 {att=UC_SIGLA} lsize=10 xref=left
>> yref=center llayer=1
> You need to add centroid to the list of types. The label is attached to the
> centroid and if you do not display that, the label won't display either. If
> you're annoyed by the centroid circle, set its size to 1 which makes it
> hardly visible.
> Moritz
