[GRASS-user] vector layer labelling doesn't work....
Paulo Marcondes paulomarcondes at gmail.com
Fri Aug 8 10:44:45 EDT 2008
2008/8/8 Moritz Lennert <mlennert at club.worldonline.be>:
> You need to add centroid to the list of types. The label is attached to the
> centroid and if you do not display that, the label won't display either. If
> you're annoyed by the centroid circle, set its size to 1 which makes it
> hardly visible.
I usually set to basic/point, size 1. Hardly noticeable at all.
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
