[GRASS-user] vector layer labelling doesn't work....
G. Allegri giohappy at gmail.com
Fri Aug 8 12:59:02 EDT 2008
> If it is needed, I can add code to turn on centroids when area labeling is
> turned on in TclTk. But a better solution IMHO is to fix d.vect so that it
> is not *necessary* to have centroids showing in order to display labels for
> areas.
IMHO this is the best solution.
