[GRASS-user] v.dissolve bugfeature / workaround needed
Maciej Sieczka
tutey at o2.pl
Mon Aug 11 22:56:32 EDT 2008
Moskovitz, Bob pisze:
> I have the v.dissolve problem too. I'm running GRASS 6.4.svn (is
> there a way to tell what svn revision I'm using?)
In the directory with GRASS source code check the .svn/entries file. 4th
line from top carries the revision number.
>> v.dissolve input=alquist_priolo_eq_zones_mrg_ll83 at PERMANENT
>> output=efz layer=1 column=FaultName
> Segmentation fault
Does this happen with all vector maps? If not, please report to Trac and
provide the sample data to reproduce the problem (a location that
contains the PERMANENT mapset alone with only the problematic vector map
inside).
Maciek
Maciej Sieczka
www.sieczka.org
