[GRASS-user] grass6.4.svn revision32686: failed to
compile r.terraflow and nviz2
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Aug 12 13:02:26 EDT 2008
On Tue, 2008-08-12 at 09:08 -0700, Michael Barton wrote:
> My understanding is that if you do a make distclean, you do not need
> to do a make clean too.
> Michael
> > I always thought both are necessary (?) after a configuration and a
> > "make".
> > make clean --> cleans "make"d files
> > make distclean --> cleans configuration files
> > Is that correct?
> > Nikos
Michael,
you are right. It might be funny but I got used to do first "sudo make
clean" and then "sudo make distclean" and, important, I never found a
crystal-clear explanation about "cleaning". Maybe I did not search
enough the web.
Kind regards, Nikos
