[GRASS-user] grass6.4 develbrunch revision 32726: undefined
	reference to `G_no_gisinit'
    Martin Landa
    landa.martin at gmail.com
    Tue Aug 12 13:28:34 EDT 2008
Sorry,
try to rebuild also gdal, etc...
Martin
2008/8/12 Martin Landa <landa.martin at gmail.com>:
> Hi,
> make distclean
> svn up
> ./configure
> make
> should solve your problems...
> Martin
> 2008/8/12 G. Allegri <giohappy at gmail.com>:
>> Noway.
>> Even switching to develbrunch I receive the same error:
>> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
>> It appears for many binaries (various vector, raster and others commands).
>> I also receive tens of warnings, but it's secondary...
>> 2008/8/12 Michael Barton <michael.barton at asu.edu>:
>>> Let me know if this solves the issue.
>>> Michael
>>> ____________________
>>> C. Michael Barton, Professor of Anthropology
>>> Director of Graduate Studies
>>> School of Human Evolution & Social Change
>>> Center for Social Dynamics & Complexity
>>> Arizona State University
>>> Phone: 480-965-6262
>>> Fax: 480-965-7671
>>> www: <www.public.asu.edu/~cmbarton>
>>> On Aug 12, 2008, at 9:14 AM, G. Allegri wrote:
>>>> Anyway, as Michel has noted from my #254 ticket, I hadn't switch to
>>>> develbranch_6 yet, so I was trying to compile grass 7 (in trunk). In
>>>> fact I was receiving tons of errors... :-)
>>>> I'm doing a brand new checkout from develbranch_6 right now.
>>>>> My understanding is that if you do a make distclean, you do not need to
>>>>> do a
>>>>> make clean too.
>>>>> Michael
>>>>> Phone: 480-965-6262
>>>>> Fax: 480-965-7671
>>>>> On Aug 12, 2008, at 9:02 AM, Nikos Alexandris wrote:
>>>>>> On Tue, 2008-08-12 at 08:45 -0700, Michael Barton wrote:
>>>>>>> On Aug 12, 2008, at 2:23 AM, <grass-user-request at lists.osgeo.org>
>>>>>>> wrote:
>>>>>>>> Date: Tue, 12 Aug 2008 11:21:19 +0200
>>>>>>>> From: "Martin Landa" <landa.martin at gmail.com>
>>>>>>>> Subject: Re: [GRASS-user] grass6.4.svn revision32686: failed to
>>>>>>>>      compile r.terraflow and nviz2
>>>>>>>> To: "G. Allegri" <giohappy at gmail.com>
>>>>>>>> Cc: grassuser <grass-user at lists.osgeo.org>
>>>>>>>> Message-ID:
>>>>>>>>      <f8fe65c40808120221o21b8ce0ax5d816981a5a358c3 at mail.gmail.com>
>>>>>>>> Content-Type: text/plain; charset=ISO-8859-1
>>>>>>>> Hi,
>>>>>>>>> neither r.terraflow nor nviz2.
>>>>>>>>> From the error log, it seems to me that nviz library name is missing,
>>>>>>>> re-run configure script to fix it.
>>>>>>>> Martin
>>>>>>> Maybe do a make clean or make distclean before compiling.
>>>>>> I always thought both are necessary (?) after a configuration and a
>>>>>> "make".
>>>>>> make clean --> cleans "make"d files
>>>>>> make distclean --> cleans configuration files
>>>>>> Is that correct?
>>>>>> Nikos
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
