[GRASS-user] grass6.4 develbrunch revision 32726: undefined reference to `G_no_gisinit'
G. Allegri giohappy at gmail.com
Wed Aug 13 14:26:55 EDT 2008
I understand that everything that needs GRASS has to be recompiled if
this version changes so much to change its interface (QGis-GRASS
plugin, GRASS-GDAL plugin, etc.). But I would like to know why the new
develbrunch_6 revision needs the GDAL itself to be recompiled. I can
understand it if GRASS would need a newer version of GDAL... is this
the case?
Just to note: everything compiled ok from me until the trunk evision
of a week ago.
It's just curiosity. Tomorrow I will start compiling...
2008/8/13 William Kyngesburye <woklist at kyngchaos.com>:
> On Aug 13, 2008, at 12:30 PM, G. Allegri wrote:
>> Thanks for the tips. Just a question: why gdal recompiling is needed?
>> Is the version changed?
>> 2008/8/12 Michael Barton <michael.barton at asu.edu>:
>>> On Aug 12, 2008, at 11:06 AM, Markus Neteler wrote:
>>>> On Tue, Aug 12, 2008 at 6:30 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>>> Noway.
>>>>> Even switching to develbrunch I receive the same error:
>>>>> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
>>>> You need to recompile the GRASS plugin, too.
>>>> Also QGIS, if you use. And the GRASS-R interface...
>>>> Essentially everything, which uses the GRASS libraries.
>>>> (we backported to 6.4.svn a method to avoid that outdated GRASS
>>>> libs are picked up, this AFAIK requires a recompilation of the depending
>>>> libraries and programs).
>>> Does this require all new frameworks on the Mac?
> The necessity for rebuilding I think means if you want your binaries to use
> a newer GRASS 6.4.
> Software on OSX has library paths and versions hardwired, so there is less
> chance of breaking something with a different version.  ie, Qgis built with
> GRASS 6.3 support will continue to use GRASS 6.3, even if GRASS 6.4 is
> installed (the GRASS app keeps versions as separate app packages).
> But if you had previously built Qgis for GRASS 6.4, then updated GRASS 6.4
> which now includes this new versioning method, THEN you'll need to rebuild
> Qgis (or GRASS GDAL plugin or R extension).
> Note: for my GDAL framework and Qgis, they use GRASS 6.3, so no updating of
> those is needed, but you do need to keep GRASS 6.3 installed.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least
> suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
