[GRASS-user] Snap a point to a line?
Moritz Lennert
mlennert at club.worldonline.be
Wed Aug 13 15:33:04 EDT 2008
On 13/08/08 21:19, Alex Mandel wrote:
> Jonathan Greenberg wrote:
>> I have a point file that I would like to have the points snapped to
>> the nearest line in a different vector file (preferably anywhere along
>> the length of the line, although the nearest line node would be ok) --
>> how do I do this in GRASS?
>> --j
> v.patch can draw lines from the point to the existing network
> v.net op="connect" can put the points on the line if you need them as
> nodes for network analysis.
or:
v.edit with the bgmap= parameter.
v.distance with output= parameter which creates a map of lines which you
can then v.patch.
Moritz
