[GRASS-user] Snap a point to a line?
Martin Landa
landa.martin at gmail.com
Wed Aug 13 15:53:15 EDT 2008
On 13/08/08 21:19, Alex Mandel wrote:
>>> I have a point file that I would like to have the points snapped to the
>>> nearest line in a different vector file (preferably anywhere along the
>>> length of the line, although the nearest line node would be ok) -- how do I
>>> do this in GRASS?
2008/8/13 Moritz Lennert <mlennert at club.worldonline.be>:
> v.edit with the bgmap= parameter.
for v.edit trick you need >= r32749
where I enabled also snapping of points in veditlib.
input maps: points,lines
1) create empty output map
v.edit map=points_snapped tool=create
2) add points and snap them based on bgmap (choose appropriate threshold value)
v.out.ascii points for=standard | v.edit map=points_snapped tool=add
bgmap=lines thresh=-1,500,-1 id=1-99999 snap=node
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
