[GRASS-user] grass6.4 develbrunch revision 32726: undefined
reference to `G_no_gisinit'
Glynn Clements
glynn at gclements.plus.com
Thu Aug 14 09:53:25 EDT 2008
G. Allegri wrote:
> I didn't know that such a backward check on library version could be
> done... my ignorance :-)
> So, you suggest to avoid gdal --with-grass. What if I need to access
> grass datas from outside grass, like with gdal/ogr utilities?
Use the GDAL-GRASS plug-in. Then, you only need to re-compile the
plug-in whenever you update GRASS.
Alternatively:
Build and install GRASS 6.3. Build GDAL --with-grass, and install it.
Use this for QGIS, GDAL utilities, etc.
Build GDAL again --without-grass and install it somewhere it won't
normally be found (i.e. not in /usr or /usr/local).
If you want to use an updated version of GRASS, build it against the
GRASS-less GDAL and run it in place.
Even without this specific issue, building GDAL --with-grass is
problematic as GRASS depends quite heavily upon GDAL, so having a
version of GDAL which depends upon GRASS creates a circular
dependency.
