[GRASS-user] strange ETRS89 settings and v.out.ogr
Tim Michelsen
timmichelsen at gmx-topmail.de
Fri Aug 15 10:58:10 EDT 2008
Hello,
I defined a test location in ETRS89-LAEA using the EPSG number 3035 in the GRASS
startup wizard.
Here is what g.proj -p > test_3035_proj.txt prints out:
-PROJ_INFO-------------------------------------------------
name : Lambert Azimuthal Equal Area
proj : laea
datum : etrs89
ellps : grs80
lat_0 : 52
lon_0 : 10
x_0 : 4321000
y_0 : 3210000
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
Now I exported a data set to a shapefile using v.out.ogr. Here is the content of
the associated *.prj file:
Layer SRS WKT:
PROJCS["Lambert Azimuthal Equal Area",
GEOGCS["grs80",
DATUM["ETRF_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["Meter",1]]
cat: Real (11.0)
a_cat: Real (11.0)
a_CODE_00: String (80.0)
b_cat: Real (11.0)
b_cat_: Real (24.15)
b_na2: String (80.0)
If I load this into ArcGIS it does complain about wrong projection information.
Here is the project file when reprojecting the data set to 3035 with ogr2ogr:
Layer SRS WKT:
PROJCS["ETRS89 / ETRS-LAEA",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS_1980",6378137,298.257222101]],
UNIT["Meter",1]]
cat: Real (11.0)
a_cat: Real (11.0)
b_cat: Real (11.0)
Is the GRASS projection file wrong or is it not "standard"? From the content
they both seem to tell the same...
I would appreciate any hint or clarification.
Thanks
