[GRASS-user] grass64 and qgis-plugin-grass
G. Allegri giohappy at gmail.com
Mon Aug 18 08:35:55 EDT 2008
As it was said in the cited post, Qgis needs to be recompile too to
use it against the last grass develbranch_6 versions
2008/8/18 Gabriele N. <gis.gn at libero.it>:
> Hello.
> Following this recent post:
> http://www.nabble.com/Re%3A-grass6.4-develbrunch-revision-32726%3A-undefined-reference-to-%60G_no_gisinit%27-td18947949.html,
> I installed so grass64 (ubuntu 8.04):
> I've just built gdal 1.5.2 (without grass)
> ./configure --with-ecw=yes --without-grass
> and grass (--with-gdal)
> CFLAGS="-O3 -mcpu=i686 -Wall" LDFLAGS="-s"  ./configure --with-cxx
> --with-python --with-widgets --with-wxwidgets --with-freetype=yes
> --with-ffmpeg=yes --with-postgres=yes --with-gdal --with-sqlite=no
> --with-motif=no --with-glw=no --enable-largefile=yes
> --with-tcltk-includes=/usr/include/tcl8.4
> --with-freetype-includes=/usr/include/freetype2
> --with-postgres-libs=/usr/include/postgresql/libpq
> --with-postgres-includes=/usr/include/postgresql
> --with-opengl-libs=/usr/include/GL --with-proj-share=/usr/share/proj
> --without-fftw --without-ffmpeg --with-readline=no
> instead of --with-gdal had to make --with-gdal=/usr/local/bin/gdal-config ?
> make
> make install
> and then, gdal-grass plugin 1.4.3 (gdal-grass-1.4.3)
> ../configure --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/usr/local/grass-6.4.svn
> make
> make install
> Now I have a problem with QGIS. If I open qgis from grass63 (installed by
> the binaries) all is well.
> If I open QGIS (installed by the binaries) from GRASS64 :
> Loaded / usr / lib / qgis / libgrassplugin.so
> qgis: symbol lookup error: / usr/lib/libqgisgrass.so.0.11: undefined symbol:
> G_no_gisinit
> If I remove qgis-plugin-grass QGIS is fine.
> How can I fix?
> Thank you
> Gabriele
> View this message in context: http://www.nabble.com/grass64-and-qgis-plugin-grass-tp19030535p19030535.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
