[GRASS-user] WinGRASS issues poll
    Ted Nebitko
    tnebitko at can.rogers.com
    Wed Aug 20 11:08:49 EDT 2008
set HOME=%USERPROFILE%
 Where does the grassrc6  file appear with the above?
With
set Home=c::/home , it appears in the c/Home directory.
I have Cygwin grass 6.0 operating from  D:/ so it was necessary to use C;/
for Wingrass.
----- Original Message -----
To: "Ted Nebitko" <tnebitko at can.rogers.com>; "Maciej Sieczka" <tutey at o2.pl>
Cc: "grass-user" <grass-user at lists.osgeo.org>
Sent: Wednesday, August 20, 2008 9:37 AM
Subject: Re: [GRASS-user] WinGRASS issues poll
> Ted,
>> I notice that the grass63.bat file does not show complete paths for all
>> functions.  Do full paths have to be substituted by the user? For example
>> rem Directory where your .grassrc6 file will be stored
>> set HOME=c:\home
>> rem Name of the wish (Tk) executable
>> set GRASS_WISH=C:\grass\tcl-tk\bin\wish.exe
>> Are there other path changes to be made?
> definetely not
> no changes or hackings are needed by users
>> set HOME=c:\home
> why do you have that value?
> grass63.bat should be as follows:
> @echo off
> rem
> rem #
> rem # File dynamically created by NSIS installer script;
> rem # Written by Marco Pasetti;
> rem #
> rem
> rem #
> rem # GRASS Initialization
> rem #
> rem
> rem *******Environment variables***********
> rem Set GRASS Installation Directory Variable
> set GRASSDIR=C:\GRASS
> set GRASS_WISH=wish.exe
> rem Path to the shell command
> set GRASS_SH=%GRASSDIR%\msys\bin\sh.exe
> rem Set Path to utilities (libraries and bynaries) used by GRASS
> set PATH=%GRASSDIR%\msys\bin;%PATH%
> set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%
> set
> PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%
> rem Set Path to MSIE web browser
> set GRASS_HTML_BROWSER=%PROGRAMFILES%/Internet Explorer/iexplore.exe
> rem Path to the proj files (notably the epsg projection list)
> set GRASS_PROJSHARE=%GRASSDIR%\proj
> set WINGISBASE=%GRASSDIR%
> "%WINGISBASE%\etc\init.bat" %*
> Regards,
> Marco
