[GRASS-user] v.db.addcol error
Martin Landa landa.martin at gmail.com
Fri Aug 22 07:29:38 EDT 2008
2008/8/22 Wesley Roberts <wroberts at csir.co.za>:
> GRASS 6.2.3 (Paper4):~/paper4-data/work/sampling > v.db.addcol map=Flight_line2_clean layer=1 column="ID,INT"
> DBMI-DBF driver error:
> SQL parser error in statement:
> ALTER TABLE Flight_line2_clean ADD COLUMN ID
> Error in db_execute_immediate()
> ERROR: Error while executing: "ALTER TABLE Flight_line2_clean ADD COLUMN ID
> ERROR: Cannot continue (problem adding column).
comma is used as column definition delimiter, to add one column use
v.db.addcol map=Flight_line2_clean layer=1 column="ID int"
to add more columns, e.g.
v.db.addcol map=Flight_line2_clean layer=1 column="ID1 int, label varchar(255)"
Cheers, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
