[GRASS-user] supervised image classification using textural
aspects
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Fri Aug 22 15:02:53 EDT 2008
Dear Wout,
Following Jonathan´s comments about window size selecion, give a look at:
RIBEIRO, M. C. ; ALVES, D. S. ; YANASSE, C. C. F. ; SOARES, J. V. ; II, F.
M. . Window size selection for SAR classification using texture measures: a
case study of a Brazilian Amazon test site. In: Segunda jornada
latino-americana de sensoriamento remoto por radar: técnicas de
processamento de imagens, 1998, Santos, SP. Segunda jornada latino-americana
de sensoriamento remoto por radar: técnicas de processamento de imagens,
1998
http://marte.dpi.inpe.br/col/sid.inpe.br/deise/1999/02.11.16.14/doc/10_213o.pdf
Best wishes,
miltinho
2008/8/22, Jonathan Greenberg <greenberg at ucdavis.edu>:
> Wout:
> This is more of a general response, rather than a "how to" for GRASS. At
> 1m, you are absolutely going to need to include some level of spatial
> processing (texture being the "brute force" way of getting at these sorts of
> things). At that resolution, trees become multi-pixel objects, and there
> will be more spectral variation within a tree crown than between any two
> trees. Which textures to try are an issue you will need to resolve by
> experimentation -- variance is often an important factor, average less so.
> The window size choice is extremely important, because each window size is
> picking up different pieces of information. For instance, for large trees
> at 1m, a 3x3 window is going to be picking up within-crown variation, so you
> will get high values near the sunlit-to-shadow transition, and near the
> crown edges, but low variation within the shadow or within the sunlit
> portions of the tree. Your window should be larger than a tree crown if you
> expect to get fairly similar values within the tree crown (which is critical
> if you want to approach this in a pixel based approach). I don't recommend
> pixel-based approaches for macro-pixel objects, however.
> When working with "hyperspatial" remote sensing data, keep in mind you
> are classifying "trees" as unique landscape objects (polygons, really), not
> the less well defined "forest" -- as such, you should try to employ
> object-based approaches. You can google scholar "tree crown remote sensing"
> to get some ideas on how people approach this problem. Keep an eye out for
> papers by Lefsky, Pouliot, Popescu, Wulder, and Leckie, amongst others. If
> you want to understand how to scale from tree crown objects to a "forest"
> I'll tout one of my papers:
> http://casil.ucdavis.edu/docman/view.php/52/141/greenbergetal2006b.pdf
> It would be cool to implement some of these algorithms in GRASS, but to
> my knowledge there is no package (you'd have to write one) -- in fact, very
> few remote sensing packages have even the beginnings of these capabilities,
> although some of the authors I mention above may be willing to share their
> code.
> --j
> Wout Bijkerk wrote:
>> Hello everybody,
>> I am trying to perform a supervised classification of false color
>> images. The resolution of the bands (IR,R,G) is 1 meter. Additionally I
>> can use a DEM as input ( hor. res. = 5m), but apparently null-values
>> within the training areas are causing some problems (see
>> http://lists.osgeo.org/pipermail/grass-user/2008-June/045261.html) so I
>> am not using the DEM for the moment. I intend to use the combined
>> radiometric and geometric modules i.gensigset and i.smap.
>> Looking at the images, I wonder if including textural features within
>> the images would be usefull: a forest canopy has a far coarser texture
>> than a grassland. Also in the Grassbook this is mentioned, and for the
>> supervised classification of saltmarshes in Germany, textural features
>> are also used (see i.e.
>> http://www.nature-consult.de/images/downl/Agit_2008_nature-consult.pdf,
>> but in German), but this is not further explained.
>> This brings me to the following questions:
>> 1) Is it usefull to make a raster with textural image features as an
>> extra input for i.gensigset / i.smap? The i.gensigset / i.smap procedure
>> is partly based on geometry and therefor on texture as well so what does
>> a texturemap add?
>> 2) if it is usefull, which textural feature is then aproppriate? I have
>> been experimenting and until now simply variance seems to make the
>> difference between forest and shrubland compared to grassland, and
>> reed-vegetation. This was using a windowsize of 5, meaning 5x5 m.
>> Did anyone have any experience with this?
>> Regards,
>> Wout
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Jonathan A. Greenberg, PhD
> Postdoctoral Scholar
> Center for Spatial Technologies and Remote Sensing (CSTARS)
> University of California, Davis
> One Shields Avenue
> The Barn, Room 250N
> Davis, CA 95616
> Cell: 415-794-5043
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080822/300d326c/attachment.html
