[GRASS-user] supervised image classification using textural
aspects
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Aug 25 08:39:09 EDT 2008
On Fri, 2008-08-22 at 16:02 -0300, Milton Cezar Ribeiro wrote:
> Dear Wout,
> Following Jonathan´s comments about window size selecion, give a look
> at:
> RIBEIRO, M. C. ; ALVES, D. S. ; YANASSE, C. C. F. ; SOARES, J. V. ;
> II, F. M. . Window size selection for SAR classification using texture
> measures: a case study of a Brazilian Amazon test site. In: Segunda
> jornada latino-americana de sensoriamento remoto por radar: técnicas
> de processamento de imagens, 1998, Santos, SP. Segunda jornada
> latino-americana de sensoriamento remoto por radar: técnicas de
> http://marte.dpi.inpe.br/col/sid.inpe.br/deise/1999/02.11.16.14/doc/10_213o.pdf
> Best wishes,
> miltinho
> 2008/8/22, Jonathan Greenberg <greenberg at ucdavis.edu>:
> Wout:
> This is more of a general response, rather than a "how to"
> for GRASS. At 1m, you are absolutely going to need to include
> some level of spatial processing (texture being the "brute
> force" way of getting at these sorts of things). At that
> resolution, trees become multi-pixel objects, and there will
> be more spectral variation within a tree crown than between
> any two trees. Which textures to try are an issue you will
> need to resolve by experimentation -- variance is often an
> important factor, average less so. The window size choice is
> extremely important, because each window size is picking up
> different pieces of information. For instance, for large
> trees at 1m, a 3x3 window is going to be picking up
> within-crown variation, so you will get high values near the
> sunlit-to-shadow transition, and near the crown edges, but low
> variation within the shadow or within the sunlit portions of
> the tree. Your window should be larger than a tree crown if
> you expect to get fairly similar values within the tree crown
> (which is critical if you want to approach this in a pixel
> based approach). I don't recommend pixel-based approaches for
> macro-pixel objects, however.
> When working with "hyperspatial" remote sensing data, keep
> in mind you are classifying "trees" as unique landscape
> objects (polygons, really), not the less well defined "forest"
> -- as such, you should try to employ object-based approaches.
> You can google scholar "tree crown remote sensing" to get
> some ideas on how people approach this problem. Keep an eye
> out for papers by Lefsky, Pouliot, Popescu, Wulder, and
> Leckie, amongst others. If you want to understand how to
> scale from tree crown objects to a "forest" I'll tout one of
> my papers:
> http://casil.ucdavis.edu/docman/view.php/52/141/greenbergetal2006b.pdf
> It would be cool to implement some of these algorithms in
> GRASS, but to my knowledge there is no package (you'd have to
> write one) -- in fact, very few remote sensing packages have
> even the beginnings of these capabilities, although some of
> the authors I mention above may be willing to share their
> code.
> --j
> Wout Bijkerk wrote:
> Hello everybody,
> I am trying to perform a supervised classification of
> false color
> images. The resolution of the bands (IR,R,G) is 1
> meter. Additionally I
> can use a DEM as input ( hor. res. = 5m), but
> apparently null-values
> within the training areas are causing some problems
> (see
> http://lists.osgeo.org/pipermail/grass-user/2008-June/045261.html) so I
> am not using the DEM for the moment. I intend to use
> the combined
> radiometric and geometric modules i.gensigset and
> i.smap.
> Looking at the images, I wonder if including textural
> features within
> the images would be usefull: a forest canopy has a far
> coarser texture
> than a grassland. Also in the Grassbook this is
> mentioned, and for the
> supervised classification of saltmarshes in Germany,
> textural features
> are also used (see i.e.
> http://www.nature-consult.de/images/downl/Agit_2008_nature-consult.pdf,
> but in German), but this is not further explained.
> This brings me to the following questions:
> 1) Is it usefull to make a raster with textural image
> features as an
> extra input for i.gensigset / i.smap? The
> i.gensigset / i.smap procedure
> is partly based on geometry and therefor on texture as
> well so what does
> a texturemap add?
> 2) if it is usefull, which textural feature is then
> aproppriate? I have
> been experimenting and until now simply variance seems
> to make the
> difference between forest and shrubland compared to
> grassland, and
> reed-vegetation. This was using a windowsize of 5,
> meaning 5x5 m.
> Did anyone have any experience with this?
> Regards,
> Wout
All this is a "burning" issue for me as well. I was looking for
r.texture as well but never found something detailed. I did some tests
on my own without success. Now I read Markus' notes [1] and I'll try to
play around sooner or later (thank you Markus).
If i.smap could auto-segment multi-layer raster maps with some kind of
input parameters (not training samples) and r.texture really does
"statistical magic", then GRASS would challenge proprietary image
segmentation/classification tools. I think that a lot of people would
like that.
[1] http://mpa.itc.it/markus/ortho_smap/orthophoto_smap_043050.txt
Greetings, Nikos
