Fwd: [GRASS-user] use pi number
José María Michia
jose.maria.michia at gmail.com
Sat Aug 23 21:14:35 EDT 2008
2008/8/23 José María Michia <jose.maria.michia en gmail.com>:
>> Is it possible to define variables?
2008/8/23 Glynn Clements <glynn en gclements.plus.com>:
> Yes; an assignment anywhere other than at the top level will define a
> variable rather than an output map. You can either place the
> assignment at the point that you would first use the value, e.g.:
> outmap = a * (pi = 3.14159265358979323846) + b
> or use eval(), e.g.:
> outmap = eval(pi = 3.14159265358979323846, a * pi + b)
Thank you, Glynn. I was able to assign the variable.
> Variables remain in scope until the end of the file.
I do not know if I understood well about the scope of the variable. If
I need to use the variable in several maps, only works if Pi is
defined in each operation. For example:
This works:
r.mapcalc '= eval (pi = 3.14159265, pi + sin (map / pi))'
r.mapcalc 'b = eval (pi = 3.14159265, pi + cos (map / pi))'
But this does not:
r.mapcalc 'b = eval (pi + cos (map / pi))'
Just out of curiosity: I searched on Google and documentation GRASS
how to do this, and could not find it. Does anyone know where it is
documented that?
Thanks again!
José María
PS: In response to messages from Glynn I forgot to use the address of
the group, so we forwarded those messages here. Sorry!
