[GRASS-user] batch export
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon Aug 25 13:05:20 EDT 2008
On Sonntag, 24. August 2008 17:13:17 Martin Landa wrote:
> Hi,
> 2008/8/24 Bruce Raup <brauplists at gmail.com>:
> > If '*index*' is meant to refer to grass rasters, then you need to say
> > something like:
> > for out in `g.list rast` ; do
> > if [ `echo $out | grep index` ] ; then
> > # process $out
> > fi
> > done
> you don't need to call `grep` here, just use "pattern" option of g.mlist
> g.mlist rast pattern=*index*
thanks - this worked:
for x in "`g.mlist pattern='*.asc' sep= `" ; do ....
Martin
