[GRASS-user] batch export
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Tue Aug 26 11:10:36 EDT 2008
On Montag, 25. August 2008 19:05:20 Martin Wegmann wrote:
> On Sonntag, 24. August 2008 17:13:17 Martin Landa wrote:
> > Hi,
> > 2008/8/24 Bruce Raup <brauplists at gmail.com>:
> > > If '*index*' is meant to refer to grass rasters, then you need to say
> > > something like:
> > > for out in `g.list rast` ; do
> > >  if [ `echo $out | grep index` ] ; then
> > >    # process $out
> > >  fi
> > > done
> > you don't need to call `grep` here, just use "pattern" option of g.mlist
> > g.mlist rast pattern=*index*
> thanks - this worked:
> for x in "`g.mlist pattern='*.asc' sep= `" ; do ....
well I was too fast with this statement - it still does not work.
When I do:
for rast in "`g.mlist pattern'*.asc' sep=" "`"; do
echo "$rast.test"; done
I get:
name1.asc name2.asc name3.asc.test
but I need:
name1.asc.test name2.asc.test name3.asc.test
any idea how to achieve that?
Martin
