[GRASS-user] Novice Query: Grass63, Cygwin on Windows startup errors, Error setting region (Problem with g.region: child process exited abnormally)
Wed Aug 27 08:25:20 EDT 2008
Katie Urey wrote:
> > so: GRASS 6.3.0, but:
> >> ENV variables:
> >> $ env | grep GRASS
> >> GRASS_VERSION=6.1.cvs
> > 6.1.cvs? How is that possible?
> I found an old ref to this in .bashrc.  Commented it out.... started
> fresh.. Ran grass63.  Saw the same error. (hung splash screen)
> Looked at GRASS* in my environment and saw a ref to 6.1 cvs again.
> My hunch is that I'm making a very simple mistake.  Would a re-install
> be easier than debugging this?
If the GRASS_VERSION is due to something in .bashrc or similar,
re-installing won't have any effect.
/etc/profile, /etc/bashrc, /etc/bash.bashrc, ~/.profile,
~/.bash_profile, ~/.bashrc, ~/.bash_login, ~/.alias or ~/.grass.bashrc
may contain settings which could affect this.
Also, if you have an old version of GRASS installed anywhere, remove
it.
