[GRASS-user] Re: Re: GRASS freezes with OpenSuse 11.0
William L. Baker
bakerwl at uwyo.edu
Wed Aug 27 19:24:42 EDT 2008
Hamish,
GRASS 6.3 starts fine with -text or -oldtcltk options. The gui freezes
with default or -tcltk or -gui options.
What freezes is the "GRASS 6.3.0 GIS Manager Map" that is a complex map.
I can't even close that window and have to logout to get rid of it.
I did the compile myself. This is not from an rpm.
No message about libgdal or missing nsres...
Bill B.
> Bill Baker wrote:
>> I have the same problem with GRASS 6.3.0 downloaded from grass.itc.it
>> under OpenSuse 11.0 32-bit. I have latest GDAL, Postgresl etc.
>> Francesco Teodori has created 32-bit rpm's for Suse 11 and GRASS 6.3.0,
>> so he must know what we are doing wrong. I have not tried the rpm's:
>> http://teodori.org/repository/grass/opensuse11.0/current/32bit/grass-6.3.0-1opensuse11.0.i586/download.html
>> I have the same freeze problem with GRASS 6.2.3 and GRASS 6.3.0-svn from
>> 2 weeks ago, both downloaded from grass.itc.it, so the freeze problem is
>> not specific to either 6.3 release or 64-bit. Something in OpenSuse 11
>> must be the trouble, but what?
> Is there an error message shown in the terminal window?
> e.g. something about libgdal.so? or missing nsres() variable?
> can you start in text mode ('grass63 -text') and run 'g.region -p'?
> I expect there is some build error with those binaries, or GDAL libraries
> on your system have been updated to a newer version than those binaries
> were built with and are now incompatible.
> I see on the download site there is a new grass-6.3.0-13.1.i586.rpm
> added three days ago. Perhaps that solves it?
> Hamish
