[GRASS-user] Re: Re: GRASS freezes with OpenSuse 11.0
Francesco Teodori francesco.teodori at gmail.com
Thu Aug 28 03:37:56 EDT 2008
Add the following repo
http://download.opensuse.org/repositories/home:/lmich/openSUSE_11.0/. After
that, update the packages. This should fix the problem.
Francesco
On Thu, Aug 28, 2008 at 1:24 AM, William L. Baker <bakerwl at uwyo.edu> wrote:
> Hamish,
> GRASS 6.3 starts fine with -text or -oldtcltk options. The gui freezes with
> default or -tcltk or -gui options.
> What freezes is the "GRASS 6.3.0 GIS Manager Map" that is a complex map. I
> can't even close that window and have to logout to get rid of it.
> I did the compile myself. This is not from an rpm.
> No message about libgdal or missing nsres...
> Bill B.
>  Bill Baker wrote:
>>> I have the same problem with GRASS 6.3.0 downloaded from grass.itc.itunder OpenSuse 11.0 32-bit. I have latest GDAL, Postgresl etc.
>>> Francesco Teodori has created 32-bit rpm's for Suse 11 and GRASS 6.3.0,
>>> so he must know what we are doing wrong. I have not tried the rpm's:
>>> http://teodori.org/repository/grass/opensuse11.0/current/32bit/grass-6.3.0-1opensuse11.0.i586/download.html
>>> I have the same freeze problem with GRASS 6.2.3 and GRASS 6.3.0-svn from
>>> 2 weeks ago, both downloaded from grass.itc.it, so the freeze problem is
>>> not specific to either 6.3 release or 64-bit. Something in OpenSuse 11 must
>>> be the trouble, but what?
>> Is there an error message shown in the terminal window?
>> e.g. something about libgdal.so? or missing nsres() variable?
>> can you start in text mode ('grass63 -text') and run 'g.region -p'?
>> I expect there is some build error with those binaries, or GDAL libraries
>> on your system have been updated to a newer version than those binaries
>> were built with and are now incompatible.
>> I see on the download site there is a new grass-6.3.0-13.1.i586.rpm
>> added three days ago. Perhaps that solves it?
>> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080828/f539d91d/attachment-0001.html
