[GRASS-user] script in python
Gabriele Nolè
gis.gn at libero.it
Mon Dec 1 09:55:27 EST 2008
Moritz Lennert-2 wrote:
> On 01/12/08 15:23, Gabriele Nolè wrote:
>> Hi Jose.
>> I changed the code by trying different solutions, such as:
>> def main():
>> vect1 = options['vect_1']
>> vect2 = options['vect_2']
>> vect3 = options['vect_3']
>> vbuffer=subprocess.Popen('v.buffer','input=vect_1','output=buffer_200m','buffer=200')
>> retcode=vbuffer.wait()
>> # Then I also tried with another command (v.db.addcol):
>> #import subprocess
>> #vaddcol=subprocess.Popen('v.db.addcol','map=vect_1','columns=prova','VARCHAR(15)')
> The parameter for v.db.addcol is columns='prova varchar(15)'. I don't
> think you can split that up into two parameters. Shouldn't this be:
> VARCHAR(15)')
> (don't know if the white space is allowed as such or whether you need to
> quote the entire parameter as "prova VARCHAR(15)")
> Moritz
Yes, I have tried in this way but not right (with 'columns=prova
VARCHAR(15)').
Now I have also tried to remove white space but ... nothing
Thanks
Gabriele
View this message in context: http://www.nabble.com/script-in-python-tp20758838p20773446.html
Sent from the Grass - Users mailing list archive at Nabble.com.
